Hi, I have an sxr that has engine problems that I am not sure what is caused by. For the first few minutes of a ride, the ski runs fine but if I turn it off or roll it on its side than it starts to bog down when reving up and only runs at 4-5 mph max under full throttle. It does this every time I ride it. I took it to the garage and the mechanic is not sure what the problem is. Do you guys know what could be causing the problem? The ski is all stock except the paint job.
Thank you
Thank you
