A couple weeks ago l bought @mightymighty2stroke glass SF.Thanks MM2Stroke! Pleasure doing business with you.l have tried for a few builds to have a ski l could ride both on flatwater and surf.Never really worked out so when this one came up for sale l got it! @McDog wanted it too,but l snatched it up! Ya never Shane,you know how l am with hulls,you still may own it one day.
So here is the plan.LB (key words right there broh's) My trusty xs735pv is going in it.Stock oem 144 pump running a 11/16 prop.Found an original carbon SF pole (thanks @Lone Octane) with a.....wait for it.....pole spring (@ScottS just for you sir!).CF turnplate with straight rrp bars.CF gas tank and XS waterbox.No trim and nothing fancy.
Brought it home and decided l just wanted to install all the parts l had and run it.Later this winter l will tear it down and make it sano.Everything has went well with assembly.l glued another insert back in where one had come off for the waterbox.Figured out with much help and advise that my 144 solas pump must be an early version because the the driveshaft was too long.Gonna pick up a oem pump today to fix that issue.
So here are some pics of the build so far
