Hi guys,
I've just got myself a new MSD Pro Digital, and I thought I'd throw up a post to see what curves other people are running.
I've used pretty much every type of CDI out there before, Advent, Vilder, Inferno, Enhancer, modded stocker so I thought I'd give the total loss a go.
My engine setup;
- 61X cylinders at 83mm
- Heavy cylinder porting (race, but still has good bottom/mid)
- Stock, untouched 62T cases
- ADA head with 35cc
- 46mm Mikuni's
- R&D Dominator with VF2 Reeds
- Factory B - limited
- Used for both racing and freestyle (can't afford 2!)
In the past, I have had good results with the Advent curve Y701-6, with the excpetion of pulling the timing out at 4500rpm.
Based on my engine setup, does anyone have any reccomendations for curve setup? I was thinking of running pretty much the same as what I was running on the Advent, but I'm wondering if the curve might have to be ramped down a bit due to the lightened flywheel, etc?
I have some conservative settings of;
25 degrees initial, 4000 retard, finish timing of 18 degrees at approx 7000 rpm.
These seem very safe, but I think I might be missing out on a fair bit of bottom end with the low advance. I am going to try them for a start and keep bumping it up until I either get detonation that I can't tune out, or fic with higher octane fuel, or I start losing power.
We have some pretty good 98 ron pump gas here in Australia that is readily available, and alos access to Avgas, and methanol.
I'm very open to your input here, as I have ZERO experience with total loss systems even though they are the same as any other CDI.
Cheers.
My engine setup;
- 46mm Mikuni's
Cheers.
