I need some of you guys to post up ur TL specs. I have my old settings when I ran the analog TL and a single pickup digital, but want to see other peeps dual pickup TL curves. Throw in ur engine, pipe, carb, pump, and prop if u want.
im running old school 4270 total loss.single pick up. 26 degrees initial advance,pull timing at 5k rpm.retard rate is 3 degrees per 1k rpm and its limited at 8800 rpm.bottom end brap is unbelievable at 26 degrees.
