msd enhancer
wondering does it matter if you use resistor plug caps with enhancer or will it effect it or has anybody had this problem first ride of the day it will shut off like 3 or 4 times start right back up then the rest of the day it will run fine done this two weekends in a row wondering maybe if it could this be the enhancer thanks for the help
no iam not sure i also was thinking it could be a fuel issue ive been thru the carbs fuel filter and tank cleaned everyting what i tinkink it could be is the last couple of times ive been out ive ran it down to about 2in from the bottom of the tank and maybe it has to prime all lines maybe thats why it stalls few times and then it runs good the rest of the day thtas the only other thing think of not sure
