Getting back into the sport and just running into a little bit of confusion on the wiring of my MSD enhancer.
Stock diagram shows red wire from start stop should connect to red wire of rectifier and have an inline fuse to the starter relay as stock cdi has no red wires?
MSD enhancer has a spliced male and female
red wire which I’m seeing one goes to the starter relay and the other to the inline fuse then connecting to unknown, leaving the red wire from start/stop switch and red wire from rectifier splicing back into the fuse? MSD enhancer diagram is hard to tell with all the gray wires.
I also have the ocd solutions surf armor bilge I am trying to figure out how to incorporate it into the ebox, its been so long I don’t recall but looks like it requires a dual bilge setup? I think I was planning on adding another bilge but never did. With this setup would the bilge just run when the ski is on or is there a way to add a manual switch as well? Picture of bilge setup below.
