- Coeur D' Alene, ID
So after 14+ years my MSD Enhancer took a poop (I think.) It went bad at the exact same time my stator rattled loose and grenaded so the timing on it going bad seems a little suspect, but after swapping in a good stator and getting the ski running on an OEM 61x CDI I am still only getting spark when I let off the start button when the MSD is installed. (Also getting same symptom with another MSD that a buddy had laying around that he didn't know if it was good or not.)
My question before I buy a new MSD to use while my TL gets sorted out is: Could the symptom I am having with these two MSD's be caused by A) not getting power to unit (powered off starter relay) or B) from a bad/insufficient ground or C) ???.
If in fact both these MSD's are bad, has anyone had any success with fixing this issue by "baking" the MSD's and brought one back to life?
I would rather not spend $300 just so I can ride for a month till my TL is sorted, but I need to do something because the stock CDI is not cutting it with my setup.
TIA
TIA
