- Floridapunk
"no similar threads were found"
Someone help me understand this setup....the timing advance plate advances the timing by 6 degrees, but there is a chance of detonation, w/ the enhancer. I could get a retard module, which, according to MSD retards through the entire RPM range. So w/ that module my timing will only be advanced by 2 degrees.(I'm using hi octane pump gas/ compression will be around 165-180 [not extreme])
There are some members out there that use the enhancer/ advance timing plate w/o the retard module, they have not detonated, and they say the setup works well.
Below are two contradictory statements from MSD, so WTF?
