MSD CDI Install
UK
Just a quick question, I have just finished installing a MSD ignition to my superjet following instructions here:
http://www.x-h2o.com/threads/21086
The engine is out of the ski at the mo, but with a quick test the electrics seem to work the flywheel turns and the plugs spark.
Just one thing before I seal it all back up, the earth wires (black) from both the start stop switch and the stator (flywheel wiring) there is a eyelet to attach to the earth terminal- thats all fine but they both split off in to a male connector, I'm not sure where these should live or should I just tape them up?
Any help would be great.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
You will always have an extra ground leads when removing the overheat sensor off the stock head. It doesn't matter if you have any pigtails just hanging there, as long as all the ground leads with eyelets are bolted down on the ground lug in the case.
Make sure you tape up the pink lead if your not using the overheat sensor and you don't want that one to ever ground out and turn on the CDI to overheat mode.
Not to thread jack here but I didn't wanna start a new thread for a similar issue. My box is split right now and I'm all hooked up. I want to use my over heat sensor so I have my pink wire from the msd to the sensor connected. Can I use either ground "T" from the stator or start/stop switch that he's talkin about to ground the over heat sensor? Should be able to cuz it's all common ground correct? As long as all it eyelets are grounded.
