dbrutherford
Parts Whore
- Fairmont, WV
I was wondering how and where the trigger plate mounted on an 800 SXR engine. I assume it mounts on the front of the case/flywheel cover like the stock stator? And i also assume that the fywheel is similar to a stock wheel...
I am planning on putting an 800 SXR engine into my 650 X2. On a 650 the stator mounts to the cases and the flywheel mounts overtop of them. There is nothing what so ever (except for the oil pump) on the case/flywheel cover.
I plan to have the SXR cases machined to accept a 650 stator. BTW does an SXR case have the places cast into the aluminum like a 750 does for a 650 stator?
Just asking. If you have pics of an 800 SXR TL setup, post up pics.
Would I be better off to just use the stock 800 electrics and say an enhancer, TBM wheel, or an Advent? I am just wondering so I can piece together the parts I need.
