Boris
The Good Old Days
- The surf-less coast
Pulled the motor out of my ski yesterday for a general cleanup and to survey the 3 new holes I made in the bottom after collecting some rather large rocks (had a blast just the same).
Anyway, my motor mount perches (those raised areas with the inserts in them) are looking rather rooted.
They started to ware away some time ago when I had some AM motor mounts that worked them selves lose and things are getting worse every time I check.
The right front one has about a 1/4" of material already gone and even the brass inserts are starting to disappear. The others have groves dug in ranging from 1/8" to 3/16".
I grabbed what I had on hand (JB Weld and some liquid nails) and filled in the voids which might work for a bit but what would be a more permanent solution ?
Glass in some metal plates ?
Guild it back up with some resin ?
Start transplanting all my stuff into my other hull ?
Engine alignment is starting to be a peal pain with the motor mounts being lower and lower.:laugh2:
