suva
57
- Just south of the Citadel, Idaho
My buddy got a '92 440sx with a 550 top end and a bunch of bolt ons for $60 the other day. The carb is pumping fuel (fuel comes out the return when cranking), if you hold your hand over the carb it will suck fuel into the venturi, but won't run if it isn't choked. He had a 44bn on it, and I bolted on one of my 44sbns and it did the same thing. I noticed the intake manifold opening is smaller, probably for a 38mm. Could that cause it to not suck fuel into the motor?
