more help! blowsion pole spring install
brett
Ventura,ca
havn trouble gettn this bolt to line up. im tryin not to mess up the threads too much. any tips?
i found the easiest way is to:
Push the the bolt to the spring, then push the spring to get bolt in a little, then hit the bolt with a rubber mallot. Rember the other side is threaded it helps to push down the pole to line it up
W
wydopen
Guest
got the switch in my hand. wiring gonna be tough. not sure how i should do it.
i hope you are kidding....call me if you need help..i did mine ultra sano all soldered in about half hr...get some heatshrink...there is a diagram in the teq faq section...super easy...you will need some connectors to go to the battery unless you wanna tap into the power line like mine...gound behind ebox if you do that
