Rickster
Matakana Menace
- Bay of Plenty, NZ
Why is it a bad idea to mix cases from different engines? i.e. top of one 62T to the bottom of another 62T?
that's what i've heard tooQJS said:I believe the cases are Line Bored as one unit hence they need to be treated as one unit.
Chris.
yamaslut said:Don't do it!!!!!
Cases are not designed to be mix matched....
this is advised by many top engine builders
Chris.
Rickster said:That is why i posted it here, to hear from the experts... I have heard it before with 'I was told by somebody you shouldn't' but never got a reason.
Line boring sounds like a good reason not to on high HP engines...:biggrin:
waxhead said:if you line bore then you are just line boring the hole the same size
if there is an issues where they are bigger tha you would not be able to use them
you can get them chaecked and measured
I would not do on a high output engine
it may work but then again it may not and if you have dollars in there then its going to be an exp maybe
