Missing thread??
Keith
Landlocked
Nebraska
I started this one yesterday. Where did it go????
Anyway, I wanted to know which hole on the turnplate on a superjet gives the quickest turning rate. Is it the inside or the outside? Should I completely sand off all the gelcoat in the areas that I am going to be adding fiberglass reinforcement? And should I remove any excess 5200 before glassing over it or will it be ok to just lay the glass and resin over it?
Delaware
The outside.....
You just need to remove the gloss of the gel coat I believe......
Shouldn't matter depending how much you going over but why not sand it off......
