What causes slight sputtering off idle, as the low speed adjuster will tune the idle just fine. It only sputters till about 1/4 throttle then is fine. Also, if the boat is on its left side it has a tendancy to go rich and die. The jets would be to the hull side, and the fuel pump to the engine side.
