Other Mid shaft play.... Need rebuild?
No it should be tight. Mine were so bad water leaked in. Itll start causing a gnarly vibration. New bearings and seals are like 30 or 40 bucks you should do it now while the motors out
SuperJETT
none
$15 for bearings/seals at a local bearing shop and maybe an hour of time, just rebuild it to be sure. Make sure the splines are good both inside and on the driveshaft side.
Matt is correct, I do it both ways just depending on how I am feeling. I have also pressed it out with the coupler still on but its easier with it off. Mine was doing the same thing but come to find out the bearings were installed incorrectly as well
Do replace the 2 o rings inside the midshaft, they'll become a bit flat with age. If water leaks past them, it will wash away the grease and both driveshaft and midshaft will (!) strip on short order.
