Surfriding Melting ground cable
Out of know where I go this problem where the rubber coating on my ground cable is burning off its the second time it's happened this week once it shorts the ground wire I can't get any response until I put a new one on I have no idea why it ever where to begin to look to solve this problem
The cable gets hot because it has high enough resistance to dissipate enough power to heat it. That effect is localized. It may be that the starter is drawing excessive current.
Yea this problem came out of no where I replaced it twice now with new cables could it be the starter relay or start stop switch holding a current the whole time Frying the wire
Not really. The current is determined by what the starter draws. The ground cable can handle that, so even a stuck relay would not cause the wire to melt if the starter is in good condition.
Current draw high enough to "melt" the ground cable would have a similar effect on the (red) positive cable, just before the solenoid contacts fry. You're not using a 12 ga ground cable by any chance?
Exactly. The melting is localized for the reasons I listed earlier.
Quinc
Buy a Superjet
California
If your power wire is getting hot, it is most likely your relay. At least that happened to me once where the rely stuck on and the wire started to smoke.
If the rest of the starting system is fine, a stuck relay will not cause the wire to overheat to the point of smoking. That wire gauge is sized to handle the starting current of a healthy system for more than just a couple of seconds.
Your stuck relay was only part of the problem. Corroded wiring and an aging starter were the rest of it.
My positive cable is staying fine
You said you grabbed the ground cable from another ski, right?
My money is still on the cable being corroded. This is extremely common in older cables. Grounding it to the intake doesn't help,either.
If you have a DMM, remove the cable and measure resistance from terminal to terminal of that cable.
Yeah I grabbed the cable from another ski the ends were clean i don't no if under the coating had any corrosion
