Freestyle max engine size on a 140 mag?
wat is the biggest size engine you can run with a kawi 140mm skat trak mag before going up to the next size? iv brought a second hand q8 hull that came with a 140mm mag with a 13/18 wich im guessing will be to small and to lower pitch to run my 10mm ada 1000cc with total loss and black jack 44s with a b pipe.
has anyone had any luck running smaller pumps on larger engines?
