Pressure check the engine, the 550's always had weak crankshaft seals. The front one was the worst. TIP: When re-doing a 550 with new crank seals, buy OEM only, and don't buy a front seal, buy 2 rear inner seals and use one for the front instead. This will give you a double lip seal for the front instead of the weak stock single lip seal that goes bad all the time.
