Malones New Skis w/ Engine Shots
SuperJETT
none
That's the same as in the Russian video that Grigory posted recently. Nice layout.
F
Freestyleriverrat
Guest
What motor is that? Is that the polaris? Looks like the gp800 setup from the bolt patter on the head and flywheel cover.
F
Freestyleriverrat
Guest
I cant identify engines well except what SJs motors look like but....
all skis are labeled with a cc then EME.....is it possible he's making his own motors now?
Not likley, he would have to invest way to much captial for a project like that. He has an engine builder and probably uses the best components available. He is making some great power but it is not that difficult with bigger motors, it is a matter of fitting it in a stand up hull.
That gp800 platform is about the same as Malones motor. Look at superramjets ski. It is not only the hp that makes the motor so great for freestyle but the a$$ load of torque they make.
ahhh seen those b4 a lot of work and time goes into the products he makes....and it is quality stuff...so the price is well worth it.
DAG
Charlotte, NC
i just just took my school loan and put it all down $45,000.00 for his 1000cc hope to get it soon :biggthumpup:
cookerq62
Life's Been Good
Upper Bucks, PA
The flywheel bolts look like polaris and so do cases/reed bolts. The motor mounts look diff though. That pipe is awesome looks like the octane dry or type 8 manifold. I can't get over the chamber. Adet16v was telln me that his ski he rode at the pittsburgh regatta had a 3/4 inch pisser :shock:
F
Freestyleriverrat
Guest
I hope you are joking, Jeff can make you a boat w/ more power for under 20K w/ a prepreg hull.
I think its an octane bottom end, happens to be the same as one of polaris twin snowmobiles motors, and either has the octane cylinders or some slightly larger snowmobile cylinders on it because they would bolt up to it. I'm pretty sure the 1000cc version is a set of aftermarket cylinders for the polaris snowmobile that has been reworked to perform in the ski instead of a sled with a clutch. I heard mark baxter built the pipe, but don't know any of that for sure
Mile9c1
X-H2O.com
Grand Rapids, MI
Who the hell keeps ordering stuff from Waterdawg? I'm thinking it might be two years before I get my ne whull :rolleyes:
