Maintenance Question
I spent @ an hour looking through past threads but could not find an answer, so bare with me if my question is a stupid one. Is there any other regular maintenance to be done on a Superjet (97) other than greasing the impellor shaft bearing? I previously owned a Seadoo many years ago, and I had to change the jet pump oil in the rear cone and keep an eye on the wear sleeve. When I bought the SJ used, it came with no manual, and the guy I bought it from said to put a couple of shots of grease in the fitting maybe twice/year. I guess it must depend on how many hours you put on the machine, but is this all there is to it, and if so, should it be lithium grease or any old automotive wheel bearing grease? Any advice is appreciated. Cheers.
tor*p*do
Squarenose FTW
NW NC
change spark plugs about every 25 hours.
no pump oil to worry about.
use waterproof grease on the fitting.
