Super Jet low compression? jetting on 46 mm wetjet 701?
i have a 701 61x from a wet jet with a 46 sbn on it running a coffman sizzler which im told is very similar to a b-pipe. im wondering what jetting to go with. its running ok the way it is i just know it has potential for more. the other question is that im at about 135 compression on both cylinders. at what point is it dangerous to run the motor? suggestions? i also have a riva 135 cc o ring head that i havent put on cus im not sure if its worth it or risky? i know i am going to order ported topend before to long for my 62t bottom abut dont really want to drop the dough for both skis, and 62t motor is priority. should i just save the head? i know its a lot of questions but it would be greatly appreciated for suggestions?!?!?!
