masterblaster
X-H2
Had a fly wheel bolt come out and the wheel came off at low rpm,it has seemingly wallowed out the cranks flywheel slot,the key has a little side to side motion in it, when the wheel is put on and pushed back by hand as far as it will go,it has a few millimeters movement each way,I know when the bolt has 70 lbs torque on it that it holds by the taper but would this cause any issues if its not perfectly centered? once it does get tight on the taper?
