- Cheney lake Kansas
"Feel the fire as he is entering the ring."
Rage composites works brawler hull
This arrived this week from Brian and Josh.
The hull Weighs 63 lbs
Arrived in white gel coat
the top deck looked almost perfect , I spent maybe 20 minutes wet sanding the top deck . The hood will need a little bit more sanding down . Hopefully if all goes well ill drop it off at the painter mid week.
At this point I am planning on painting her BANG red. With black diamond turf.
The plans are almost a straight swap from my superjet. T/x motor,head,b pipe,44's, cats trim, blah blah
I need to buy a smaller fuel tank as the stock tank will not fit and probably a x metal water box . I may be able to modify factory pipe water box .
Brian was great through the entire hull construction updating all the time with pictures and progress.q They even installed plumbing inside the rear of the hull for hot foot mod . And installed my epic scupper.
All inserts came with hardware ,(motor mounts, pump ,ride plate midshaft.)which was a nice surprise .
they included additional inserts so I can install fuel and water box where I need them .
New style adjustable ride plate is being tweaked and will ship to me soon.
I have loved the looks and design of this hull from the beginning from nickwad. And anxious to ride the hull.
Having a Stunt hull , I really like the ride and feel of a short light hull , I don't enjoy riding my superjet much anymore it seems to long and heavy . With the difference in weight and hull shape I know I will be happy with the feeling of more power from the Motor from the superjet in the new hull .
