Other Lamey cylinder x 62T cases bolt (????)
Hello guys,
I never had a Lamey motor without a girdled head and so I never had to get long bolts for this since I always used a girdled studs...
Now Im in a need of this.
Will OEM long cyl to case bolts work on it???
IT IS STD STROKE.
thanks
Gera
wsuwrhr
Purveyor of the Biggest Brapp
Hello guys,
IT IS STD STROKE.
thanks
Gera
Gera,
Is this a billet cylinder or a cast cylinder?
I am not sure what you are asking.
BTW...no "Lamey" cylinder needs a girdled head.
Brian
munki63
Epoxy is my duct tape
Canada
If your in a jam get stainless ready rod, use a nut to tighten down the cases and another for the cyilnders :shrug:...works and its much cheaper, I think its a m5 thread you would be using
Thanks guys.
Yes. The link U provided is exactaly my cylinder.
Brian, It is billet and has the ADA/DASA non girdled head.
I wish to have OEM bolts instead of threaded studs with a double nut.
thanks
Gera
Proformance1
Liquid Insanity
Vendor Account
New York Crew
Mine came with the cyl, I think they are diff than stock, Longer possibly. Just PM Brian i'm sure he has them in stock
They should be in a plastic bag all by themselves, 6 bolts about 2 or 2 1/2" long
Hummm.
I tought it had came with but I only got the head/cyl boltos.... (as picture)
Still thinking about what to use to attach cyl/case.
thanks
Gera
1-10-2011 08:47 AM
geraban19
bolts
Thanks for the help Brian.
Well, I got this brand new top end from Idok (actually it belonged to a friend of him who had a warranty after a bad casted cyl).
I got it last july and just building it at this time.
I didn't even know that the bolts should come along.... I never got when ordering from DASA direct or thru Leg Drag...
If I can get the OEM bolt Im fine... it is cheap... or if U can send to me I will provide the address.
Thanks
Gera
Obs. U should have my address (Im a DASA costumer) under GERALDO MELO (1581 Brickell ave # 1806 Miami-FL 33129)
No my friend, Im in Brazil.
If he has the bolts with him I will be more than happy if he gives it to Kevin Collins from Legdrag/Wamiltons.
Is it possible?
Thanks
