D-Roc
I forgot!
- Dirty River Rider
I am having problems shutting off my ski. sometimes it will shut off normal and other times i press the kill switch and nothing happens. That is when i usually yank the ski around and ride back out from shore for and keep riding for anywhere between 30 seconds to 2 minutes and then the ski shuts off as if i hit the kill switch. I am wondering what actually happens when you press the red button. On stock ignitions i am thinking you press the button and do not have to hold it down to kill the motor. On total loss systems you have to hold it until the motor stops spinning. Does the kill switch ground out spark on the coil or does it just give a signal to the cdi to stop spark? If i know how it kills the motor i may be able to find the problem as it is some what sparatic. Yesterday when riding a new problem occured as well. ski ran great but once in a while would not rev up more then a high idle. the more throttle i give it the more it would sputter/backfire (as if only getting a bit of spark). It would fire up and idle back to shore perfect....and not shut off. :banghead: i am going to cut back the plug wires, clean all connectors, and crack open the e-box to check the grounds in there. If any of you guys have some ideas i am open to checking them out to see if it will fix it. I hate sparatic electical problems, and i believe them to be related.
