Kawi stator bad?
tor*p*do
Squarenose FTW
NW NC
750sx no spark, coil ok wires ok, battery ok, switch ok
stator wires show:
blue/green = 280 ohms (normal = 400 - 600?)
red/purple = oo
brown/brown = oo
bad?:ugh2:
WFO Speedracer
Alabama
Pretty safe bet regrettably checking those with an ohm meter usually does not yield good results,the only foolproof way to test those is to replace it with a known good component.
tor*p*do
Squarenose FTW
NW NC
OK so maybe the stator has gone a little bad
amazing it ran as long as it did! :biggthumpup:
tor*p*do
Squarenose FTW
NW NC
carnage for the night
fried stator
chunks of metal inside flywheel (see arrow)
air cleaner is toast
stator and coil + old SJ coil all go off to JSS for rework:fingersx:
im just wondering what would cause that kind of damage. did the flywheel come loose or is the crankshaft having excessive play or did the stator just fall apart and then get caught up on the flywheel.
tor*p*do
Squarenose FTW
NW NC
John called, stator is officially dead ; (
BUT he had a rebuildable core
and made me a package deal
to get back on the water by this weekend :Banane35:
