chrisdoc0608
insulting
- rocky mount, nc
For the past week i have been getting information abt trying to solve my 88 650sx problems. It all began with my ski cutting off at full throttle in chop, then it began cutting off at full throttle whenever. next the ski began to idle then cut off if throttle was pressed, from there it began to progressively get worse until the point that it would crank up then cut off. as of right now the ski will crank and immediately die. if i hold the throttle down then crank it it revs up and then dies out as if it burns the gas it has, then runs out. so here is what i have done. i began by checking all cooling lines (when it was running) i checked all of the fuel lines for clogs, there was nothing. i emptied the gas, and tryed a using a diff CDI, which didnt change a thing so i put my old one back on and replaced the boots on the wires. i removed the carb and took the needles out as well as the jets and looked for anything that may be blocking them, the carb was in immaculate condition, everything in it looks brand new. so i put it back togather and put it back on the ski. I just installed a westcoast head also (187psi on each cylinder) so i put some 93 gas in and mixed it 40:1 (probably a little rich) and gave it another shot, it cranked up and died i took the lines off of the carb and cranked it to see if fuel was pumping, and it was. what the hell is going on here... i dont know what else to do and all i want to do is ride!!! ive had the ski since jan and i have only been able to ride for a total of 4hrs. someone please help me!
