- california
Hey i have a 90 kawasaki x2 but i realized that it takes on a great amount of water. I Used a air compresser and blew air threw the flushing kit hose connection, and felt no draft. When i run it with water i cannot see any running water through anything, yet there is water rapidly rushing into the hull (when its hooked up to the hose) the hull water tight. The water comes in only when it runs. Does it have to do with burnt gasket? cooling promblem? what are some areas to check and is this common?
thanks
thanks
