just got a MSD enhancer, what should i use for plug wires and caps
yeah just got an MSD enhancer and will be needing new spark plug wires and caps and was wondering what i should use. Ive also heard talk about resistor caps and such and dont know what i should use.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
I use non-resistor cap and R plugs, the main reason is resistor plugs are easier to find.
You also can use NGK resistor plug caps and STD non-resistor plugs.
One or the other is fine, but not both resistor cap and resistor plugs.
#ZERO
Beach Bum
Florida - U.S.A.
Use the MSD right angle boots with the stainless terminals part number 3311.
For the coil wires you can use 8mm tinned-copper silicone-wire.
I would only recommend using the resistor end caps with non-resistor spark plugs.
so can someone sum up whether or not to go with a resistor cap or a resistor plug? and a certan brand to go with. Should i buy the ngk racing wire with the resistor caps or should i piece together my own plug wire and caps. Also i am having a hard time finding non resistor caps so if someone could let me know the best route that would be great
Here's a good setup: A new, stock SXR coil, MSD plug boots and terminals, and BR8ES/BR8HS plugs.
Finland
I dont want resistor or i dont want non resistor.. I just want to know which one is the best to go with..:dunno: Some people say i can't use resistor caps with BR7HS plugs and some say that i should.. So i was thinking what kind of plug & cap combo people are using here..?
Rather than creating a new thread, my question is related to this. What are "caps"? Ski I bought has msd enhancer and msd boots so I presume the wires are msd. I don't know what "caps" are so I don't know if I should run resistor or non resistor plugs. Ski currently has resistor plugs but last owner was running short shaft plugs with aftermarket head so I don't fully trust his choice of resistor vs non resistor plug. Thanks.
