300/440/550 js550 footholds?
I've done a bit of Google searching and the only forum posts that talk about installing foot holds on a 550 are expired and the pics are gone. Anyone have any info on installing footholds on this machine? I am just starting out on standups I got the riding part down and now I'm working on subs and such.
Any other recommendations on inexpensive/worthwhile mods for this machine?
King Kang
Never enough tray time...
Cary, NC
These are all valid questions that I'm interested in too. Also, when you install footholds into a JS550, where do you relocate the fire extinguisher to?
I got to take a look but I'm sure I will find some where. They also sell mini fire extinguishers as far as I know.
Nor Cal
I did not do foot holds but cutting the tray and making it wider was the reason for my fire extinguisher re location
Nor Cal
Thanks. ill see if i can post some more pics i de turfed the hull and started measuring it all out then grabbed a saw and started cutting . as far as fiberglass goes its not rocket science id recommend going down to home depot buying fiberglass mat and resin and start playing with the stuff . And go find a damaged hull that if you mess up its no big deal and start cutting and glassing
Excellent! Now I'm thinking about cutting the side walls off all together & just using footstraps.. that thing looks sick!
So ifi want to learn about hull modification, I should just search "fiberglassing hulls" or something?
