DirtTOwater96
Pre_mix.. addicted
- Illinois
Hey guys i got a 1980 js 440 that had a starter that wouldent engage amd needed carb work. I got the starter figured out and carb has been gone through.
The ski will start off primer fuel but will not stay running after primer fuel burns off.
The kid i got the ski off of said he just replaced all the fuel lines wich is true there are new, that makes me think maybe there routed wrong??
Can i by pass fuel selector by running the fuel pickup line strait the carb to ruel out some stuff?
and the carb im talking about is a bn44mm im pretty sure, it has a high speed ajuster, a low speed ajuster,and a pilot jet ajuster i think?? And the ajuster on throttle linkage for idle, it has 4 bolts for flame arrestor on top of carb. From what i read this is a 44mm bn correct ??
So if some one can take tge time to tell me or show me how fuel lines should be routed ? and what the problem could be i would realy appreciate it ?
Ski has: L S exhaust manifold,ocean pro intake manifold,west cost pipe cone and exit pipe if that helps.
Thanks for any ones time who takes tge time to help me out.
