Jf650AE secondary coil ohms readings.
US
Thanks for any help here in MD. The cdk2 bored out to 40mm with the 750 jets & low / high speed screw set to a 91650specs.runs great. Until a restart. No spark. Secondary coil reading of 16.2k. I'm thinking the regulator rectifyer is spent.& not charging the battery with enough CCA? Any help ? The books specs.is 2.1-3.1k . The çdi coil is still hooked up so maybe the high resistance is the regulator rectifyer is bad and causing the 16k reading? I hope this makes sense. I ran the Ski long enough to warm it up and set an awesome steady idle. It was a long enough time to kill the battery's CCA instead of keeping the battery charged.
Sent from my SM-A426U using Tapatalk
