SXR jetting ?
idaho
just finished my 09 sxr, trying to figure out the proper jetting and pop off press. The ski is ported, milled stock head w/ 175 comp. wet pipe, v-force reeds, taui ceti f/a, on the stock carbs, riding around 3000 elevation.
i would just use the jets that came with the pipe thats all i use and i have a similar set up and i like my pop off pressure around 21 psi i have a wetpipe,jsu girdled head 185 comp, tbm reed spacers,v force 3 reeds, r&d manifold, novi 48's and the jets that came with the pipe work great im not sure how much your motor being ported would change the need for jets but if your good at tuning the carbs the u dont need to have perfect jetting just takes more adjusting on the screws
