Jetting Specs for SJ with pipe
IceRocket1286
Metro Detroit
What size jets should I use for my ski? Single carb, stock 650 carb whatever it is... with a speedwerx pipe. Pipe is the only mod, I will be removing the choke for a primer. I do not know what jets are in it, neither did the previous owner.
Look up what Factory Pipe recommends for their type 9. Jet up one size for both low and hi, and adjust from there.
Tuscaloosa, AL
These specs would be assuming he is running duals............ not sure, but I dont think there are any specs for Jetting with a type 9, just like the B Pipe Mod Chamber, they do not provide specs for that setup.
There is no jetting specs for his set up................. look up FPP for a 95 SJ with the limited pipe (Wet - B Pipe) if the jetting specs say 140 low then put a 155 high (Just an example), figure on 15 points about high and low then go from there.
romack991
homebrewed
Warsaw, IN
another factor is that its not a true 701, you've still got the 650 transfers, cases, and intake.
didnt you buy the engine and pipe together, so shouldnt this already be atleast close to the right jetting?
IceRocket1286
Metro Detroit
its a 650 with 701 cylinders and pistons etc. I dont know what the jetting is, and I couldnt even tell ya how to find out, never done it before.
EDIT: I pulled it off just now and took the cover plate off. This is were I become CLUELESS! now someone help me
waxhead
wannabe backflipper
gold coast
no
i would think you would be wanting about a 120-130 low and a 100-120 high
with about 20-30 psi popoff
i know there is a huge variation in my jets i am telling you but this is how i would start out and work from there
jetskiking
Im done sanding!!!
Dallas Georgia
This is what protec recommended for my motor thats a 6m6 bored to a 701 and ported 135 main ,120 pilot ,2.0 needle and seat, 65g spring.This is with coffmans pipe. They are all different so something tells me that you are going to learn about carbs real quick.
jetskiking
Im done sanding!!!
Dallas Georgia
You have to pull the little cover beside the jets and its written on the side. Its a little eisier to see than the one on the jet. The spring is determined by color. I think the 65g is silver
waxhead
wannabe backflipper
gold coast
wow thats close
it was just where i would start off
to check what your n/s seat are then you have to pull the seat out and have a look
it will be written on it
IceRocket1286
Metro Detroit
the spring is silver, wound clockwise. the seat is the big jet on the left, correct? and the needle "hangs" off of the little mechanism which the spring pushes against, correct?
I pulled them out, cant find any engravings.
IceRocket1286
Metro Detroit
alright, ill look tomorrow. Ive got to go to hockey and beat up some old guys. So, I should look on the needle, right above the black point on it, that i do not see when installed?
