I put a 62T out of a WaveVenture in my 93SJ. What my question is I put a RIVA non-girdled head with gas domes on it with a set of WestCoast Velocity Stacks. The motor has been bored to 82.5mm. Will I need to do any rejetting on this? I am running a stock 701 superjet exhaust. Attached is a picture of the engine. I started the engine yesterday and it seems to run fine on the stand and idles good. I just don't want to lean it out when Spring gets here when I put it in the water. I have not done any adjustments to the carbs other than cleaning out the jet side. I completely tore the motor down put new seals, gaskets and pressure checked.
