- Central Jersey
Whats up, pretty new to the site but not new to riding. I have been buying a bunch of parts off of people on here and I am finally making some progress, so I figure I post up my build. I was going to waste more money on my 05 SXR, but I decided to get smart and pick up an SJ. In December, I picked up a hull off here from a guy in va that striped the hull, put in a set of footholds, reinforced, refoam, smoothed all scratches in it, and sprayed it with an epoxy primer. A bunch of time and money later, I finally have all the parts I need, finished the final body work and spray the hull. Its nothing special compared to what most guys have on here, but heres what I got for now:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com
ffice:smarttags" /><st1
lace w:st="on"><st1:City w:st="on"></st1:City></st1
lace>
<st1
lace w:st="on"><st1:City w:st="on">HULL</st1:City></st1
lace> AND STEERING <o
></o
96 RN <st1:City w:st="on"><st1
lace w:st="on">Hull</st1
lace></st1:City>: Painted Jeep Wrangler- Rescue Green Metallic, 17 oz Biax Reinforcement throughout, 1 Layer of Carbon on sides- Clear Coated, Gun metal gray Base/Cleat coated engine compartment, One-way dumped in pump area<o
></o
Stock Hood w/ Blowsion Carbon Liner<o
></o
R&D Intake Grate<o
></o
Wamiltons Ride Plate- Going to D-cut it<o
></o
Rebuilt Midshaft Housing<o
></o
New Stock RN pole- Cut -3"<o
></o
Xmetal Lowered Bracket
Xmetal Pole Bolts<o
></o
Xmetal Adjustable Steering System<o
></o
Xmetal Throttle Lever<o
></o
WCF Chin Pad<o
></o
X-Metal Hood hooks- Hull Side<o
></o
25mm underpadding and Black turf<o
></o
Jetmaniac Hood Strap<o
></o
Rotary dash bilge switch w/ Blowsion Guard<o
></o
Single Rule 500 Bilge<o
></o
Black 45 bilge outlet<o
></o
Front Tow loop w/ Bow Eye<o
></o
Primer kit (plunger style)<o
></o
ODI Ruffian Grips<o
></o
<o
></o
MOTOR <o
></o
61x/62t Freestyle Ported cylinder and Cases<o
></o
82.5 Pro X Pistons <o
></o
New Stock Dual 38 Carbs w/ Stock FA's<o
></o
Pro Designs- Cool Head- Girdled <o
></o
New Factory B-Pipe<o
></o
JetWorks flow control valve<o
></o
Cold Fusion Kawi style Couplers<o
></o
New fuel lines<o
></o
New cooling lines throughout
Kenny Engine Keepers<o
></o
<o
></o
ELECTRICAL
MSD Ignition
JSS Coil
Deka ETX9 battery
<o
></o
PUMP
Jetmanic Bored Exit Nozzle<o
></o
Wamiltons Stubby pump cone<o
></o
Rebuilt Pump and New Wear Ring<o
></o
Solas Prop- Sending it to Impros to repitch to 13/17
<o
></o
<o
</o
<st1
R&D Intake Grate<o
Xmetal Pole Bolts<o
WCF Chin Pad<o
ODI Ruffian Grips<o
<o
MOTOR <o
New fuel lines<o
<o
ELECTRICAL
MSD Ignition
JSS Coil
Deka ETX9 battery
<o
PUMP
<o
<o
