Cannibal
Tasty Human
- Summit Lake, WA
I got the correct (so I thought) cable adapter from X-Metal and found some issues:
For one, my cable wouldn't even come close to fitting through the hole. I had to file and drill out the hole to finally get the cable through. I wasn't sure what the adapter was for until I realized that the Kawi cable sits farther back (or rather toward the front of the ski) than the Yamaha cable (duh, I removed a UMI to install this one and the mount was farther back on that one too).
So I go to install said adapter and find that it won't even come close to fitting over the end of my cable. Do SXRs have larger cables than earlier Kawis? I have a 94 750sx cable here and the threaded end and that next part that flexes are very thin. I measured my cable and it's .3775. The adapter ID is only .3250. Now before someone says drill it out, I should point out that the retainer groove diameter is .3660, so no go there.
Has anyone else run into this? Do I have some beafy aftermarket cable? Did they send me an adapter for early Kawis and not the correct one? What gives?
Here's the pic X-Metal sent. I will also talk to them tomorrow.
