is this normal? bogging from low
Penken
whoomp there it is!
Umeå, Sweden
hey i was ridin my superjet alot yesterday.
it´s a 650 superjet. coffman sizzler. k/n filter. bored abit. hooker impeller, worx intake grate.
when i´m ridin realy slow and pull the throttle all the way. it just sounds like it dies. then i pick up some speed and do the same thing and it works fine.
is this normal?
jetting problem?
maybe i have a to high pitch impeller? i have no idea on what pitch i have since the previous owner bought it. anyway to find out?
my sparkplugs are abit on the darker side. but it runs fine at wot.
SuperJETT
none
As long as there aren't other issues, it's probably your low speed carb tuning is too lean. Open the low screw 1/4 turn and see if that makes it better any.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Sounds like a carb issue. Could need rejetting or a possible rebuild. Like Sjett said...
Try turning out the low adjuster up to 1/2 turn and bump up the idle screw about an 1/8 turn.
Penken
whoomp there it is!
Umeå, Sweden
thanks for the tips.
which screw is lowspeed and which is highspeed? stock SN 650 carb.
sorry for the newbie questions
