SXIPro
JM781 Big Bore
- Here on the 'X' mostly
To install a bilge pump in the coupler area of an FX1? I've put them in SJs a bunch of times back there, but there is zero room back there in the FX1... What am I missing?
I have one I mounted on the right side of the coupler .. made a L bracket to mount it on the coupler cover bolt. Works great...
I wonder if the new adjustable bracket from Hot Products would make that any easier?
Combine the bracket with a Rule 350 or 500 as they are the lowest profile of all the available pumps.
FYI, the Rule 350’s are identical to the 500’s except for a slightly smaller impeller that sits a bit higher on the shaft and has much more tolerance to running dry.
Seaflo bilge pumps are by far the best. Multiple sizes. 4 year warranty they stand behind. Replace no questions asked with free shipping if you ever break anything. Left mine on 450 miles back from pismo and its still fine. A bilge pump should be able to run indeifnitely without any water flowing through it
