- amarillo ,tx
is a girdled head only necessary if your doing barrell rolls or are planning useing a exhaust that is not top mounted, i doubt ill b able to pull off any barrel rolls but am planning on putting factory pipe on my 96 sj
You will get mixed answers on this.
I know a ton of people myself included that ran B pipes for years with stock heads and never had any trouble. However, you do hear of the occasional cylinder cracking. If you are just looking to stay on the cheap side of things I would go for it. 61x cylinders are really cheap these days so worst case is that if you had to you could just pick up another cylinder.
+++++++totally agree
i know also many people use dry pipe with the stock head never have a problem
my first superjet was like this .
i think that barrel rolls had nothing to do with girdled head..spend your money for some porting and boring (max 82mm to be sure) and never worry about cranking
i
