- Minnetonka, Mn
Ok so I have this weird problem. My ski runs perfectly engine wise; but, it runs exactly like it is full of weeds. Some back story: A friend and I were riding (pretty hard) and we decided to switch skis. After a little while some water got in my tank and we came back and fixed it. When we got back out it idled fine, but when you hit the throttle it just revs to the moon and doesn't go nearly as fast as it should (5-10 mph). There are NO weeds; even though, that is exactly what it feels like. I took the intake grate and ride plate off, and can see the (presumable stock) impeller. Slightly pitted and chipped but no major damage. When you turn the impeller by hand, it turns the drive shaft, and vise versa. If I hold the drive shaft, by putting a screwdriver in the hole behind the impeller, I can not turn the impeller by hand. The coupler seems fine, no gaps, good condition rubber. Any ideas as what to check first? Right now I see two options: Pull the entire pump and rip it apart so that I can check everything; or, pull the engine, and check the coupler connection. 1985 550. Aftermarket intake grate, and ride plate.
