intermittent spark
I last used my ski about a month ago, it was working great when last used. Last week I decided to winterize but it would not start, so I tested the spark, it only fired a couple of times every once in a while. I checked all the connections, no problem seen.
I have a second 750sx that runs fine. So I swapped the electronics box and the magneto but the known good components did not make the spark start on the bad ski. That leaves the flywheel as the only component that was not swapped. I hate to pull the flywheel and it does not seem reasonable that that would be causing the problem.
I even swapped the battery trying to rule out all possibilities.
Does anyone have any ideas?
