Intake manifold gasket help
I just had the motor apart on my '09 SJ. I went to put the intake mani on and need some clarification on gaskets. Based on the OEM diagram it looks like there is a metal gasket sandwiched by two rubber gaskets underneath the reeds. The metal gasket I got from Blowsion has a thin rubber gasket fixed to one side. Can anyone tell me the order of these?
Thanks
Blue
Judging your cheapness
St Cloud Florida
Thanks
Sj uses a paper gasket on each side of the metal spacer. Paper metal paper. You need all 3.
Sent from my SM-N950U using Tapatalk
