Custom/Hybrid Instructions for Factory type 4 water lines
bondra131
Thaat's braptaastic!
I just installed a type 4 exhaust on my superjet. it has a stock head on it for now but i put a fitting in it with a line running out the hull. the manifold is set up for dual cooling which i dont have so i capped off one fitting and used the other for the incoming water line from the pump. my question is- do i run a line from the fitting on the top of the chamber to the stinger fitting (fitting with the jet in it)? and then run another line out of the hull from the fitting just before the stinger? that is what made sense to me but ive seen different in some pictures...
