Super Jet Installing limited chamber in a Superjet...
I just dont remember the last time I installed a limited chamber.
II did run a lot of mod chamber w/ weld and them the newer ones without the weld.
In this build (Lamey/DASA cylinder / std stroke) I decided to give a limited chamber a try.
It is horrible to fit in a SJ hull.
A couple years ago a friend of mine decked his FPP manifold to prevent the chamber from hitting the hull.... I thought it kind of weird but Im considering to do this.
Any opinios???
Thanks
Gera
Dmac80sc
Here
I havent installed one buy have heard a few people just denting the chamber to make it clear or just putting some hydro turf where it would rub the hull.
D-Roc
I forgot!
i think it depends on the rubber coupler that is used too. i never understood why it was so hard to install the chamber when i could put mine together without even swearing. my new pipe has a differennt coupler hose that is straight up a PITA. i dented and turfed.
