- Lake Norman
Does anyone have any step by step instructions on how to take of the old bars and install some new 0 degree bars? I think I can do it but pictures or explanation would help. Thank you.
Don't forget the start/stop switch. There's a little nipple that locates in a hole on the stock bars that you'll need to grind off when you change to aftermarket bars. It's pretty easy to remove, and you don't need it anyway. Just make sure you grind it flush so the switch clamps back down properly. I'd also modify the grips part: Remove POS stock grips, install shiny new ODIs :biggrin:
Yea I got some Rogue grips. I just saw that I have to grind down the nipple, what if I just left it? It seems to fit fine? Will it not work? Thanks
What bars do you have? Most aftermarket bars don't have the locator hole, so you have to grind it off.
Or you can drill a new hole in the new bars like I do.
Yeah you could...or just tighten the screws and it dot he exact same thing without extra work:biggthumpup:
Damn Med Students
i drilled a new hole.....maybe i just have a roaming start/stop, who knows.
