Hey guys thanks for all the good reading. I have a 95 Super jet with these mods.I'm just getting back into the sport.The last ski I owned was a 1987 js550 so there is a little learning to do.I would like to make this ski have more bottom and mid for freeriding with out getting in to deep .I called Impros and they are telling me I should look at a 9/15 3mm cut back. I have not found a single post where anyone is running this prop. Most are running a 13/16 or 13/17.David says that would be his choice and i should not have any trouble with the stock revs.I don't want it to run out to fast do I. I'm just re learning and really don't care about speed..... to a point .He says it will still be a 40s ski and that is fine.It has some punch now ,but from a 550 what do I know.I'm sure Impros knows what they are talking about just wonder why no one else is running this set up.Thanks for your comments.
Kevin
Factory b pipe
ada head 170 psi
46 single carb
Jet dynamics ride plate
(getting the fly wheel cut in aweek or so)
(nozzle bored as well)
Allum ac hand pole -2
quick steer plate MFG ?
works 205 intake
Prop pitch now ? I have not pulled it ,but this ski seems to have been built for top end with the original R+D intake grate and ride plate also a little history from the (joe bag of doughnuts not very on top of things mainly a sit down guy ) owner.
Kevin
Factory b pipe
ada head 170 psi
46 single carb
works 205 intake
