accbr
addicted
- Lexington, KY
Having some starting problems with the squarenose. It worked fine a few weeks ago, and all I've done to it since then is put the roundnose pole on it. I promise. I just put the tank back in primed it and tried to test fire it. Won't start. I disconnected the black and white wire for the kill switch, and it still won't start. Even bypassed the start switch. Pulled the plugs and they were fouled from cranking it too much. New plugs. Still nothing. Grounded a plug to the motor, and it's only sparking when I let off the start button. It's cranking really fast even when the plugs are in. I do have an MSD with 6m6 ignition, that I've been running since last year. I read godocgo's MSD sucks thread. So I checked the battery, and it's reading 11.93 volts. He said in his thread it turned out to be the starter draining too much juice. Would 11.93 volts be too low to cause this? If they're that sensitive I'm putting the old CDI back in. I'm charging the battery now to see if that helps. I'll check the voltage across starter solenoid if it doesn't. I hate opening that box up.
Or is she just mad because I put a roundnose pole on her? I took my time, and I think it looks good.
